2022-02-03, 00:13
I have three questions for members of this forum regarding the movie library.
I am using KODI v 19.1 on Windows 10 and using the Xconfluence skin.
The first question is about the flags for each movie title that show on the movie library page.
I have a number of movies in my collection that have the same title. For example, I have two movies titled "Criminal". One is made in 2016 and the other is made in 2004. Often, I am changing from a x264 version to a newer x265 version of the title.
Both movies are loaded into my library in the proper manner for KODI to find them and they play fine. Each movie is in its own folder and follows the correct naming convention for KODI eg: Movies 1\Criminal (2016) x265\Criminal (2016) x265.mkv; and
Movies 4\Criminal (2004) x265\Criminal (2004) x265.mkv.
The problem I am experiencing is: when renaming the movies with the correct year and codec (x265) so I can differentiate between the two movies, it appears I am creating some condition that causes the flags on the movie page of the library screen to disappear. And I am unable to get the flags back - ever.
I use Media Center Master to collect background, fanart, poster and folder images and to create the .nfo and .xml files that work in KODI.
If the movie name does not need to be adjusted for the correct year or codec, I simply move the files to the collection and KODI adds it to the library. After scanning to the library is completed, the title appears in the listing and when I move the cursor to the movie title, all the flagged information appears. Whether the title is x265 or not is irrelevant. Kodi shows all flags.
If the movie name needs to be adjusted for the correct year, or I am loading a x265 version, I amend the movie title in the .nfo file and the .xml file to indicate the year and codec (eg. Criminal (2016) x265 and Criminal (2004) x265). After the title and/or codec is adjusted, I refresh the title using the information page setting and the new, adjusted title appears in the listing, but the flags disappear.
If I rescan the library, instead of refreshing the title, the flags do not reappear. I have even deleted the files and reloaded the titles in the collection with or without the adjusted .nfo and .xml files, (no year nor codec) but after rescanning the library the flags still do not return.
Is there an additional switch that needs to be set to "force" all the flags? Is there a memory or buffer that needs to be cleared or deleted before amending the title? Or, is there a better method to adjust the movie title for the correct year and/or codec that allows the flags to remain?
Can anyone assist in resolving this little quandry?
My second question is about the order KODI usts when scanning titles to the movie library.
I currently have six drives in my server. After moving the movie files to the server, I open KODI and use KODI to scan the files and add the new movies to the library using local information. The new files are scanned and the titles are added to the library.
Can someone please tell me the order that KODI scans the various drives in the server?
Is it possible to have KODI only focus on one drive when updating the library instead of scanning all six drives for new titles?
My third question is about the .nfo and .xml files that Media Center Master creates.
Do the files created by MCM take the place of the .nfo and .xml files that are created by KODI when backing up the library? Or, do I need to take the extra step of backing up my movie library to ensure the correct title information is saved and new .nfo files are created by KODI? I remember reading something about this topic a while ago but cannot find the information again.
Thanks to those who can assist.
C.
C.
