Full Version: Shared MariaDB10 database is not shared...
In my house I have three RPI's-2 installed running OpenElec Kodi Leia V18.9. All three share the same MariaDB10 database on my NAS box. The database is called Kodi_Movies116. All three run smoothly and share the database as they should.
I also installed Kodi Leia V18.9 on my 64-bit PC and, of course, placed a file (advancedsettings.xml) in the directory C:\Users\myusername\AppData\Roaming\Kodi\userdata.
As soon as my PC-Kodi fires up I can see my NAS box being very active. Apparently, my PC-Kodi is having a busy conversation with my NAS box. Which is a good sign because my PC-Kodi knows that MariaDB10 on my NAS box is the target. Unfortunately, the PC Kodi creates its own database (named Kodi_Movies116116) instead of sharing the existing database Kodi_Movies116.
This is strange. The file advancedsettings.xml clearly shows the tag <name>Kodi_Movies116</name>. Is there anyone who knows how I can force my PC Kodi to talk to the defined database Kodi_Movies116 on the NAS box?
Here you can see the contents of my advancedsettings.xml on all my devices (RPI en PC).
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.110</host>
<port>3307</port>
<user>kodi</user>
<pass>mijnwachtwoord</pass>
</videodatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
</videolibrary>
</advanceds
(2022-02-04, 12:41)absmienk Wrote: [ -> ]<name>Kodi_Movies116</name>
Do not use version numbers in your database naming, that's for Kodi to handle internally also in regards to updates, hence the Kodi_Movies116116 result. Stick to 'Kodi_Movies'.
Sorry Klojum, it took a while before I could test this.
As I said before my RPI created a MariaDB database on my NAS box. The database was automatically called Kodi_Movies116. After that I started Kodi on my PC which created the MariaDB database called Kodi_Movies116116.
I solved the problem with this:
  1. On MariaDB delete the databases Kodi_Movies116 and Kodi_Movies116116.
  2. On the PC and on the RPI open the file advancedsettings.xml with an editor and remove the line that begins with the tag <name>. That’s where the database name is supposed to be defined. Save advancedsettings.xml.
  3. Start up Kodi on the PC. It will create a database named MyVideos116. Populate it with the data of your movies and TV Shows.
  4. Now start up the RPI. It will talk to MyVideos116 … as it should.
Obviously the line with the tag <name> is totally ignored by Kodi. I can put anything I like in the <name> tag. Kodi doesn’t care.
(2022-02-15, 13:05)absmienk Wrote: [ -> ]Obviously the line with the tag <name> is totally ignored by Kodi. I can put anything I like in the <name> tag. Kodi doesn’t care.
It is not ignored, otherwise the database name Kodi_Movies116116 would not come up.
But it all seems to be working for you now, so that's good.
Thread marked solved.
