Full Version: HDR playback: VolumeOSD breaks White/Blacklevel for kodi above 19.1
I'm stuck with Kodi 19.1 because the Volume OSD in Windows 10 breaks White/Blacklevel when playing HDR content
HideVolumeOSD does not solve this issue.
I'm using a Wndows Bluetooth Remote (Obsmart) so I have to use "+" and "-" keys which is a bit uncomfortable.
Graphicadapter is from AMD.
Any Ideas ?
Thank you!
70197
There is Kodi 19.3, is that also a problem?
And install Kodi 20's nightly build as portable, and compare the two.
(2022-02-06, 13:58)Klojum Wrote: [ -> ]There is Kodi 19.3, is that also a problem?
I have this problem with all Matrix Versions above 19.1
Did not try Kodi 20.
When pressing volume button the picture somehow resets and black looks like grey.
Then watching SDR content after HDR content, black is too dark.
This does not happen when using the Kodi Volume, only the System Volume OSD causes this behaviour.
Problem is gone with latest Nexus.
End of monologue ;-)
FYI
This will also be fixed in Matrix v19.5
