2022-02-08, 13:16
is it possible to add additional view types for the actor menu or modify the existing ones? What I want to achieve is an actor view with larger actor images similar to this one (the screenshot is from Amber):
https://ibb.co/9qCBVXr
The "Icons" view cuts off the images and in the "List" view the images are very small.
Maybe this is possible by modding the skin? If yes, where would I have to look?
I am using Aeon Nox: Silvo 8.01 with Kodi 19.3.
Kind regards
Kind regards
