Full Version: Netflix addon only works for 2 minutes.
Log1: https://paste.kodi.tv/rolimoyebi.kodi
log2: https://paste.kodi.tv/conifaleyo.kodi
Hello,
I try to run the nexflix addon installed via the CastagnaIT repository. The logs are up there. The problem is, that only the first 2 minutes of the videos work. I really mean the first 2 minutes, NOT the first 2 minutes I watch.
The audio runs normally but the video gets extremely laggy. If i rewind to a place < 2:00, everything works fine. If i go to > 2:10, it starts lagging.
In log2 I started to watch netflix from the beginning of a movie at 18:12:11, I stop watching 18:14:32.
In log1 I accidentely pressed "resume from 2:33" and it was lagging from the start. I went back to the start of the movie and everything was fine again.
Anyone has an idea what is going on here? Temperature, CPU and Swap all are looking good, no sudden jumps.
Sun Feb 13 18:11:54 CET 2022 T:62, mem avail: 338560, swap: 1280
No reply yet Sad
Anyone got an idea what to check?
Can you try downgrading your widevine cdm to version 4.10.2252.5?
4.10.2391.0 is basically busted on ARM devices (RPi in your case)
See here for some straightforward instructions
https://github.com/xbmc/inputstream.adap...1021585184
