2022-02-16, 13:06
I have seen similar questions like this but not with this problem.
I have a computer that i only use for media sharing with windows 10. My set up is a Nvidia shield next to my 2 Tv and android tablets and phones with Kodi 19.3. This week i upgraded one of my Hdd in the computer to o 8tb disk. All my disk appears in kodi media-library like before. Im able to brows all the 3 old disks but when i go to the new disk it asks says (Lock Preferences for SMB://192.168.1.13/f) F: is my new HDD.
when i type the login and Password nothing happens. Its the same on both Shield and tablets and phones.
I only have this problem with the new disk, not the old ones. Everything else works as it should.
I have tried everything that comes up when i google it.
I installed PLEX and added F: and it worked all good. so the problem seems to be in Kodi. I also installed Kodi on the computer and added f: and it worked.
I cant find the problem. Pleas help im going crazy.
- I had to set the file sharing connections from 128 bit to 40-50 bit. AFTV see all my files now and doesn't ask for SMB lock preferences.
- I have password protected sharing off
- SMB different level 1-3
- And what ells that comes up
- removed all other disk than F: didn't work.
