2022-02-17, 14:19
I originally set-up my KODI in such a way that it would launch PowerDVD to play content ripped from BlueRay discs. However when I moved from Leia to Matrix I had some issues; PowerDVD not starting, then not closing, annoying pop-ups, PowerDVD starting even when it was not supposed to etc. So while trouble shooting I decided to disable playercorefactory.xml, and I noticed that on Matrix, with Amber skin, the experience when playing BlueRay-based files is that this now feels quite "luxurious" and satisfying. Good picture, good sound, reasonable disc-like behaviour, possibility to select subtitles and audio et cetera! So I am leaning towards using the integrated KODI player also for normal play of blueray material in the future, and therefore to leave playercorefactory.xml disabled. However, in certain instances I might want to manually trigger my PowerDVD player, from within KODI, to be able to access the original disc menus to allow for the playing of bonus materials etc.
So my question is: is it possible somehow to trigger the start of PowerDVD and play of a selected movie/TV show through an individual button or option solution, but not using the playercorefactory.xml file?
