2022-02-19, 23:24
2022-02-19, 23:47
(2022-02-19, 23:24)JREED Wrote: [ -> ]Does anyone knows how to post screenshots or JPEG pictures or PNG picture on this forum?Yes...
Button 14 or 18 to upload images
Some others that may be useful...
Editing a post seems to catch a lot of members out as the Edit options are very discrete and easily missed. See image...
How to quote...
2022-02-19, 23:49
Thread moved to website and forum support
2024-02-27, 14:29
Great question! Posting images on the forum is a breeze. When you're composing your post, simply look for the "Insert Image" button, usually located in the toolbar. Click on that, and you'll be prompted to select the image file from your device.
2024-02-29, 13:27
(2024-02-27, 14:29)Griffonan Wrote: [ -> ]Great question! Posting images on the forum is a breeze. When you're composing your post, simply look for the "Insert Image" button, usually located in the toolbar. Click on that, and you'll be prompted to select the image file from your device.
Now, if you're worried about the file size being too large, you can easily compress the image before uploading. Tools like compress image are perfect for this task. They help reduce the file size without compromising the image quality, ensuring your post loads quickly and looks great.
2024-02-29, 13:28
(2024-02-29, 13:27)Griffonan Wrote: [ -> ]So, feel free to capture those screenshots or JPEG/PNG pictures, compress them if needed, and share away!(2024-02-27, 14:29)Griffonan Wrote: [ -> ]Great question! Posting images on the forum is a breeze. When you're composing your post, simply look for the "Insert Image" button, usually located in the toolbar. Click on that, and you'll be prompted to select the image file from your device.
2024-02-29, 16:38
(2024-02-27, 14:29)Griffonan Wrote: [ -> ]When you're composing your post, simply look for the "Insert Image" button, usually located in the toolbar.
ignore the post count grabbing posts by this user, the forum does not host images so these posts are incorrect
if you click insert image you will be prompted for a url where that image is hosted on another site external to this one, it will not prompt you to upload anything from your device
the following posts indicate there may be a file size limit but since images are not hosted here then it's not a concern for here, if you would like to optimize your images that's completely up to you but it's not required and just creates an extra step
