(2022-02-21, 12:19)gn77b Wrote: [ -> ]Platform is Raspberry Pi 4 with LibreELEC 10 (Kodi 19).
The problem is the combo of the RPi4 and the used video format. 4K/h264 is not a widely implemented video standard (it may be popular in the anime world, but that's it), and not many video cards have hardware-acceleration built in for that format. Hence with that disabled, the slowish RPi4 CPU can only do so much.
So either you get some htpc hardware that is more powerful/capable of handling 4K/h264, or you need to convert your videos into 4K/h265-hevc, which much better supported by video cards including the one in the RPi4.
(2022-02-21, 13:27)Klojum Wrote: [ -> ] (2022-02-21, 12:19)gn77b Wrote: [ -> ]Platform is Raspberry Pi 4 with LibreELEC 10 (Kodi 19).
I see. I noticed 4k/h264 is pretty rare but I ran into more files in this format recently. So you're saying that the RPi4 isn't capable of hardware decoding 4k/h264 or support for it isn't implemented on Kodi's side because it's not a popular format?
(2022-02-21, 14:20)gn77b Wrote: [ -> ]So you're saying that the RPi4 isn't capable of hardware decoding 4k/h264 or support for it isn't implemented on Kodi's side because it's not a popular format?
It's not just that the video decoding is not implemented in Kodi's video engine
ffmpeg, but this specific video decoding is not supported by the hardware (in your case, the RPi4). Again, a htpc with enough grunt will overcome this and decode these videos okay via software (=CPU) decoding.
As you yourself said. "I noticed 4k/h264 is pretty rare".
I get it, thanks. Any recommendations for HTPCs that can decode this (or pretty much everything) in SW?
I don't know why I added "in SW" at the end
I meant HTPCs that can decode everything and I don't care how.
