2022-02-21, 20:13
I need your help - I'm struggling with syncing my library via MariaDB. my setup was running smoothly for years until NVIDIA messed everything up with their update and now I'm not able to get my MariaDB setup up and running again. Would be awesome if someone would maybe have an idea what I could try next to get it working again
my setup until now:
- Synology NAS Diskstation DS916+
- Windows 10 PC
- 1x Nvidia Shield (2017)
- 1x Nvidia Shield TV (2019 - Tube)
- all running Kodi Krypton v17.6 synced via MariaDB5 (on my Diskstation) and SMB Shares
after the gruesome NVIDIA Shield update nothing was working anymore so I decided to start from scratch and I also thought updating KODI wouldn't hurt (I did hold on to Krypton for so long because of GRID. Which I still think is the most awesome skin for Kodi ever built...)
I have upgraded all my clients to Kodi Matrix v19.3 and also installed MariaDB10 on my Synology NAS (since I thought I'll also upgrade DSM to v7 if I'm already in upgrade mode... which I have not done yet). Adding shares on my Windows 10 PC was not an issue at all, everything works fine, connections are there, but as soon as I'm trying to sync my clients via MariaDB 5 or MariaDB 10 (I now have both instances installed, because for now as a workaround I'm still using MariaDB5 and 2 older Mi TV Boxes that are still running Krypton 17.6 until I have solved the Matrix setup. And so I tried it with port 3306/MDB5 and also port 3307/MDB10). But in both cases KODI is slow as hell. New databases get created and the connections are there, but I have to wait more than 30 seconds until the page gets loaded und even more until the thumbnails show up. Playing a file does actually work, but again it takes about 60 seconds from hitting the play button until it actually starts to play. Even stopping a video takes more than half a minute until the video is gone. Even selecting "Setup" (any actions that are not related to my library) take multiple seconds
So to sum it up - SMB shares are fine, MariaDB-sync is still working perfectly fine for my Mi TV boxes, but as soon as I'm adding the mysql reference to my advancedsettings.xml Kodi Matrix slows down
my Windows machine log does not show any errors entries at all, I just found some noticable lags with some of the entries, but to be honest I can't really interpret them
https://paste.kodi.tv/oqamawahoy.kodi
so if anyone has any tipps it would be highly appreciated
my setup until now:
- Windows 10 PC
