Full Version: Cannot delete TV shows tag
Kodi 19.3
Windows 10 Pro 20H2 64-bit
Intel i5-10500
64 GB RAM
The title sums it up: I've tried to delete a TV shows tag (that I previously created) via Context Menu -> Manage -> Remove from library but it persists.
Debug logs: https://paste.kodi.tv/mevupuriha.kodi
Thanks in advance.
(2022-02-21, 21:27)bejhan Wrote: [ -> ]ve tried to delete a TV shows tag (that I previously created) via Context Menu -> Manage -> Remove from library
I can confirm that it does not work for TV Shows.
Removing the tag from Movies does work.
Maybe @black_eagle can have a quick look... https://github.com/xbmc/xbmc/pull/18549
In the mean time you can use the Remove TV Shows option. Highlight all the tv shows to be removed and the tag will be removed.
(2022-02-21, 21:53)Karellen Wrote: [ -> ]In the mean time you can use the Remove TV Shows option. Highlight all the tv shows to be removed and the tag will be removed.
That worked. Thanks!
(2022-02-21, 21:53)Karellen Wrote: [ -> ]I can confirm that it does not work for TV Shows.
Maybe @black_eagle can have a quick look... 18549 (PR)
Ha, the joys of the to-do list eh?  Added to it!
