I just installed Estuary Mod for v19 on Matrix.
In the version compatible with V18 there was a widget in the TV Shows screen of the next episode to watch (instead of entering the specific TV series and selecting the desired episode).
This was the best feature of this skin, does anyone know how to re-enable this widget?
Thank you
(2022-03-11, 00:22)_BJ1 Wrote: [ -> ]Install Embuary Helper.
I installed, and then what? I didn't see that option appear after installation.
Is this not what you mean? Maybe you have to enable the widget (Settings -> Skin -> costumize Home Menu -> TV Shows -> Manage Ittems for TV Show widget)
(2022-03-12, 11:32)_BJ1 Wrote: [ -> ]Is this not what you mean? Maybe you have to enable the widget (Settings -> Skin -> costumize Home Menu -> TV Shows -> Manage Ittems for TV Show widget)
This is exactly what I mean.
I don't have a setting: "Manage Items for TV Show widget"
These are the options I have:
And this is what I have if I press "submenu1":
BTW, how do make the image be embedded as in your previous post
(2022-03-12, 13:25)Clonimus74 Wrote: [ -> ] (2022-03-12, 11:32)_BJ1 Wrote: [ -> ]Is this not what you mean? Maybe you have to enable the widget (Settings -> Skin -> costumize Home Menu -> TV Shows -> Manage Ittems for TV Show widget)
Clonimus74
The Estuary skin Mod you appear to have installed is 'pkscout's Estuary Mod for Kodi 19 (Matrix) as linked here:-
356349 (thread)
The @
_BJ1 Estuary skin mod can be found here which is a completely different skin mod, hence why your widget settings are different:-
366400 (thread)
As for embedding images, use the picture icon in the message tools when preparing a post. If using Imgur, use copy/paste from the 'Direct Link' on Imgur.
Hope this helps.
Edit: @
_BJ1 You beat me to it on the reply!
(2022-03-12, 13:40)Dumyat Wrote: [ -> ] (2022-03-12, 13:25)Clonimus74 Wrote: [ -> ] (2022-03-12, 11:32)_BJ1 Wrote: [ -> ]Is this not what you mean? Maybe you have to enable the widget (Settings -> Skin -> costumize Home Menu -> TV Shows -> Manage Ittems for TV Show widget)
@Clonimus74
356349 (thread)
The @_BJ1 Estuary skin mod can be found here which is a completely different skin mod, hence why your widget settings are different:-
366400 (thread)
Hope this helps.
Edit: @_BJ1 You beat me to it on the reply!
This is quite confusing :-)
Thanks, i will replace one mod with the other LOL
Many thanks
@Clonimus74
356349 (thread)
366400 (thread)
Hope this helps.
Yep, that was it! many thanks
Thank you all for your help
