2022-02-26, 16:37
Hi, alot of movies are all of the sudden hidden for the user. I'm on Kodi 19.3
The movie is not visible under movies. If I go to video / files and navigate to hte movie folder the folder is presented as empty (its not empty on disk). If I navigate using kodi file manager to the same folder I can see the .mkv. If i start it I can see it access information about the movie from the library.
How can I fix this? thanks
edit: I can search the movie, and its presented in the search result but whewn I select the movie it will navigate to nothing.
