Hello,
Was wondering, if we have Now Playing in Theatres and New Movies Coming soon widget for this skin?
Thanks,
With Regards,
Its allready in there if you scraped movies and installed estuary info addon. you'll see it at the home menu -> movies section.
Thank you so much. I was missing that addon
Thanks for helping out on this.
I'll mark this thread as solved.
Where is this addon? I only see the Embuary one.
(2023-07-29, 22:13)itwasallablur Wrote: [ -> ]Where is this addon? I only see the Embuary one.
For In Cinemas / New Movies you need plugin.video.themoviedb.helper
You can go to Skin Settings > Supported addonsÂ
to see which addons are needed for different features.
