2022-03-17, 21:44
I have a very weird behavior and I'm not really sure in which direction I should look into. It seems like Kodi cannot change anything on my filesystem any longer, nor is it capable of recognizing changes/updates (like adding a new TV show episode and hitting "Update Source"). See the following examples.
I have never had this issue before - the only thing which I changed recently was installing 19.4 (LibreELEC 10.0.2). I am running an Intel NUC, media files are on my Synology NAS. It might be related to 19.4, but it might also be a coincidence.
I have added a new episode of "Talking Dead" on my NAS/file system. In Kodi, I then went to my source and hit "Updates Source"... but the episode does not show up at all. Instead, the poster thumb looks corrupt:
I initially thought, something got messed up somehow with the scraping process so I removed the complete "Talking Dead" folder from the file system. I then ran "Clean Library" - which should detect the missing TV show and remove it from the database (and hence, the show should not be listed any longer in Kodi under "TV shows"): but the show is still there (with the corrupted poster thumbnail).
Next day I watched an Episode of "Dexter". Normally, Kodi marks an episode as "watched" after it has played it until the end - but it did not happen at all. Episode (no. 8 in the screenshot) stays as unwatched. Even when I right click the episode and select "Mark as Watched": the episode remains as "unwatched". In addition - for whatever reason - the thumbs of the episodes which I watched since then, also look corrupted:
Made another test with another tv show today: same result: after updating sources, nothing is found. It feels like it doesn't matter what I add/change in the filesystem, somehow Kodi does not detect it when updating the sources.
I can however play all content without any problems.
I have no idea what is going on or what this behavior is caused by ... so I would super appreciate any help or advice.
Many thanks!
Many thanks!
