My failed ppa compile -
https://forum.kodi.tv/showthread.php?tid=367453
Current Debian straight from source -
I looked at my error files a bit closer. Apparently it was a dependency missing. libdrm-dev (in this case for Debian). It didn't jump at me before until you said that. I didn't differentiate the configure with the compile. At any rate it's burning through the build at the moment, seems fine thus far... been going for 10 minutes or so now. I had also installed libpthreadpool-dev at some point in another failed attempt. I'm not sure if it is necessary as I didn't get any further after it. Only after the drm package did it get this far. I'll test it at some point to see what happens.
*EDIT* later that night...
Well it did finish. Nexus running now. Thank you much for the nudge in the right direction.
jmgibson1981 I can upload Nexus packaging Git for Buster and newer Debian releases to Debian Salsa repo.
I looked through your control file diff - the dependencies you deleted are actually alternative package names used in Ubuntu and/or in older Debian (like buster).
The rest is fine from the first look.
Unfortunately I still have things to settle after my family's evacuation from Ukraine before I can do 19.4 and estabilish 20.x builds in unofficial repo.
This includes access to powerful buildservers which I can use to build 50 supported packages.
Take care of your family first. That is the most important thing. This stuff is irrelevant compared to that.
Indeed. I just cleaned up the alternatives and had to edit one or 2 because they arent in debian but are in ubuntu. the default-libmysqlclient-dev in particular on debian. Is called something else in ubuntu.
