Maybe you could try cleaning the folder and filename and remove all that garbage?
MMovies-NEW/Nightmare.Alley.2021.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT/Nightmare.Alley.2021.1080p.BluRay.REMUX.AVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT.mkv
How about just simply naming it Nightmare Alley (2021)
Ok.. I tried to install it again. I also tried o install confluence skin and some other add-on and failed
Perhaps I'm having a more basic issue? I'm using hLeia 18.6
https://paste.kodi.tv/atetewezez.kodi
jalcaid001
The problem seems to be your old Windows 7 OS.
If you look through the log, there are quite a few errors with internet peer certificates that have expired. For example lines 619-624 This will continue to be a problem for you until it is fixed.
First check that you have all available Windows 7 updates installed.
I don't see you trying to install the scraper via Install from zip method. Did you try that?
I updated Windows 7
Same problems updating/installing addons.
(2022-03-22, 19:10)jalcaid001 Wrote: [ -> ]I updated Windows 7
Your certificates need to be updated. Sorry, I can't tell you how to do that as I don't know.
Maybe someone else will come along and explain or try a google search.
Interesting.. I reinstalled 18.6 with and empty config and saw the problem still
I installed latest, and problem is gone. I can install MovieDB and I can scan correctly for content
Wonder why, it was working before.
I'm seeing some other problems on a platform w/o add-on installation problems. I'll update.
