PVR & Live TV Support
MythTV
> How to build for Windows?
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
jmgibson1981
2022-03-27, 03:58
The Mythtv pvr addon is missing from the 19.4 repositories. If you go to it's main page the links do nothing. Is there a way to build the windows version of it? Linux is easy enough but I've never compiled something on Windows.
Karellen
2022-03-27, 04:09
Ah, looks like the pvr repo is playing up again.
I have checked a few different pvr repos and the versions are mixed again
eg
https://mirrors.kodi.tv/addons/matrix/pv...ws-x86_64/
Fuzzard
did you fix this last time with @
emveepee
jmgibson1981
Download the correct version from the above repo links
Fuzzard
2022-03-27, 06:19
That'll be a @
phunkyfish
one that one sorry.
phunkyfish
2022-03-27, 10:29
The correct link is here:
But unfortunately a nexus build has been added there by mistake. You can down load it and install it manually.
alwinus
wsnipex
any ideas? I don’t recall how we fixed this last time it happened.
jmgibson1981
2022-03-27, 17:55
Thank you folks. 19.0.5 pulled and worked fine. Unsure if I should mark this solved while you guys hash it out. Thank you again.
MythTV
