2022-03-30, 09:47
I have a LibreELEC setup running on a RPi4.
Since I upgraded my LE9 (Leia, Kodi 18.9) system to LE10 (Matrix, Kodi 19.4), UPNP has stopped working.
I can still browse the library but when I want to play a video, the UPNP player (VLC in this case) just isn't able to play the file.
The logs seem to point to a permission error with SMB accessing the server (Synology DSM7 running on a DS1821+).
The weird thing is that I can play the same file (using the same SMB share) without issue on Kodi.
Has something changed in the UPNP set-up that could cause this permission error?
FYI. My other LE system (also running on RPi4) still on LE9 (Leia, Kodi 18.9) isn't showing this behaviour and is able to stream the file(s) from the same server over UPNP just fine.
Log file upload: https://paste.kodi.tv/gilicemira (Line 2735 shows (one of) the permission errors).
