Full Version: "Customise Home Menu" does not work
Hi@all,
I am still very new to Kodi. So I can customize the main menu I installed fTV.
When I go to "Customise Home Menu" in Settings -> User Interface -> Skin -> Configure Skin, nothing happens.
Can anyone help me?
with best
pixel24
You need the FTV version that contains script.skin.skinshortcuts or you need to install skinshortcuts then try again .
 https://www.dropbox.com/s/ygfrp5tifk84wd...r.zip?dl=0
I have the same problem with Version 19.4 and the dropbox link from the previous post doesn't work.
Any help is much appreciated.
Having the same issue with fTV.  Customize home menu button just stopped working.  I need help  re-installing script.skinshortcuts.  The posted links do not work, any help would be great, thanks
Check edited post above for folder.
