Full Version: Can't build or run tests
I have never run the test suite before. When I follow the instructions on the Linux build page it says:
Kodi has a test suite which uses the Google C++ Testing Framework. This framework is provided directly in Kodi's source tree.
Build and run Kodi's test suite:
make check
Build Kodi's test suite without running it:
make kodi-test
But none of those commands succeeded. I ran them from the top level directory like the rest of the build. I have successfully built and run the gtest for the component I was working on (StringUtils) . This required me to copy it over to it's own directory and massage it to not depend upon Kodi.
But now i need to run the tests with Kodi to test more of the code.
I should have said that I am working with Matrix 19.4
I made a clean checkout, followed Ubuntu guide, then Linux guide and was able to execute make check command.
cd $HOME/kodi-build
cmake ../kodi -DCMAKE_INSTALL_PREFIX=/usr/local -DCORE_PLATFORM_NAME=x11 -DAPP_RENDER_SYSTEM=gl
make check
[100%] Built target kodi-test
Scanning dependencies of target check
Test project /root/kodi2/kodi-build
        Start   1: TestSysfsPath.SysfsPathTestInt
  1/609 Test   #1: TestSysfsPath.SysfsPathTestInt .........................................   Passed    0.62 sec
        Start   2: TestSysfsPath.SysfsPathTestString
  2/609 Test   #2: TestSysfsPath.SysfsPathTestString ......................................   Passed    0.30 sec
        Start   3: TestSysfsPath.SysfsPathTestLongString
  3/609 Test   #3: TestSysfsPath.SysfsPathTestLongString ..................................   Passed    0.24 sec
