Hi
at first: beautifull skin!
but...
i use it on with a dlp-projector and the fonts i see are to big:
see the screenshot:
i woul like choose the fontsets in the settings.
but i can't. there is just a "default" selection.
in the font.xml are all the other selections, i can't select
please help
I think the 4.3 version only has the default font at the moment but its still being worked on
At this point the resolution you are using is not fully supported.
It's using font.xml in the PAL folder which only has the "Default" font to select from.
Maybe if you ask real nice someone could make you a quick fix
thx for help.
i found the xml
I had the same problem with my plasma (native res 1024x768 widescreen PAR 1.333) but solved it be deleting the PAL folder altogether.
Yep, it looks like your projector is using the 4:3 version of the skin and that is still being worked on at the moment (there will lots of updates for this in the upcoming release)
As Hitcher says, you could try deleting the PAL folder and then it will just scale the 720p version of the skin to fit your screen.
