Full Version: Playing a Playlist
Is there a way to use JSON to play an existing playlist (smart or m3u)? It looks like Playlist.GetPlaylists only returns a playlist of items currently playing and not all playlists on the system.  I found a thread from 2013 that confirms this behavior, but there was also a discussion of changing it and somehow 2013 is almost ten years ago.
Anyway, if the above doesn't work, is there aanother way to accomplish this? All I am trying to do is play an existing playlist, but before I spend hours trying to see if I can do it with Player.Open (I am very new to JSON so it takes me forever...) and sending it the file location of a playlist on the server, it would be great if anyone could confirm if that might work.
What about:
https://kodi.wiki/view/JSON-RPC_API/v12#Player.Open
Doesn't this work for you?
I cannot test this currently, but the command should look like this:
{ "jsonrpc":"2.0", "method":"Player.Open", "params":{ "item":{"directory":"special://musicplaylists//myPlaylistFileName" } }, "id":1 }
From my testing your suggestion is correct but,
it seems special:// does not work and you have to specify the actual underlying pathname
if you have an m3u playlist you have to say it is a file
if you have a xsp smart playlist you have to say it is a directory
I have been trying to work out how to open a smart playlist in partymode which the api documentation says  should work,
but I cannot understand how to do so, as my knowledge of json is well below what is needed to understand the api docs
if anyone can provide an example of the correct command I'd be very grateful
I've just returned to this project and found the solution in case anyone else need it.  The json below will clear the (Video) playlist, load a specific playlist (myplaylist.xsp), and play it.
[{"jsonrpc": "2.0", "id": 0, "method": "Playlist.Clear", "params": {"playlistid": 1}},
{"jsonrpc":"2.0","id":0,"method":"Playlist.Add","params":{"playlistid":1,"item":{"recursive":true, "directory":"special://profile/playlists/video/myplaylist.xsp"}}},
{"jsonrpc":"2.0","id":0,"method":"Player.Open","params":{"item":{"playlistid":1,"position":0}}}]
Found here.
