Full Version: Build Kodi 18.9 on Arch Linux
Hello guys,
I want to build Kodi on version 18.9 on my Arch Linux.
I found this on the arch linux forum : https://bbs.archlinux.org/viewtopic.php?id=264310
But when I launch Kodi, I have this error :
/usr/lib/kodi/kodi-x11: error while loading shared libraries: libnfs.so.13: cannot open shared object file: No such file or directory
I found libnfs.so.13 on this website but not for Arch Linux.
If you know how to build old version of Kodi or install in other way, it's help me a lot.
Thank you Kodi Forum ! Smile
I tried downgrade kodi but this have an error with KODI-BIN dependences ...
if you want to run outdated software, arch is the wrong distro for you. if you really need to(why?) you will have to install the old dependencies aswell. look at the AUR and maybe make an pkgbuild with all the packages you need and than install.
You probably need to build 18.9 against newer versions dependencies.  Just check out the last 18.9 PKGBUILD commit and build from that.  https://github.com/archlinux/svntogit-co...887cea4df4
