2022-04-29, 10:31
I've moved the default position of some of my movie and TV show category nodes and also created a couple of new nodes as well.
Everything works, but for a long time now I've noticed that every time I start Kodi, the category nodes for movies and Tv shows are not displayed from the first node.
This means that on every occasion after starting Kodi if I want to use one of these nodes, I click right from the main menu item, then have to scroll back to the left on the category nodes to the first or 2nd item as I use these a lot.
I'm just curious if this is actually the expected behaviour or if anybody else is seeing the same thing happening? To me, it doesn't seem to be correct. I did wonder if these category nodes have some sort of default control, which is forcing them to display in this way at start-up? I had a quick look on both the home.xml and includeshome.xml, but couldn't find anything immediately obvious that might cause this to happen.
Here's a screen shot of my TV Show Nodes once Kodi has been started. On the right side is how it should look:-
So in essence, my first 3 category nodes are not shown on start-up currently for some reason.
Rather oddly, the same thing is not happening for music where I have also moved/created new nodes. The category nodes for music are shown correctly at start-up.
