2022-04-30, 06:17
I am using IPTV Simple Client and for some odd reason the channel icons that load up into the channel view only partially load from the .m3u list. Not quite sure why. I get this inconsistency across multiple platforms (Win 10 and Android) and was wondering what could be holding up the icons from fully loading. What's even more bizarre is that there are differences between the ones that choose to load on Win 10 vs. the ones that choose to load on Android. I've even tried different machines and there is no similarity between what will load and what won't. Because I'm grabbing from a .m3u list, I can see the paths, and I know the icon URLs are listed in the file. I go to those links directly, and they will load up in Chrome. Is there any way to force ones through that don't instantly load via a shortcut or keyboard command? There isn't a separate icon file for this service. I have removed IPTV Simple, data cleared the General and Guide, force closed Kodi, deleted Kodi, reinstalled Kodi, reinstalled IPTV Simple, put the .m3u back in, force closed Kodi, restarted, and it still causes the same issues, with inconsistent channel icon loadings from the .m3u. Any suggestions
