Hi. I want to create a flag that would be showed when a certain word is inside the path to the videofile or in the file name. Example: "remastered", "spanish",...
Is it possible?
Yes it is possible.
You will need to add a new image to the textures.xbt file which holds all the flags, then update the skin files to use it.
I am not a skinner, so I won't be able to help much.
Maybe check out how some other flags are called...
https://github.com/mikesilvo164/Aeon-Nox....xml#L1039
