Full Version: Customising search menu
Hi, I'd like to customise the search menu at the top of the screen. Specifically, I want to add pictures search from the search function included in the mypicsdb addon.
I found the search menu to be defined in includes.xml and IncludesHome.xml. I don't know if that's the best way forward or how to modify them, though.
Any ideas, anyone..? Smile
I've try to answer your PM but you have your PMs disabled... No
1. If you know how to skin code, the search dialog in top home menu it's open from this button, and code for the search dialog is here.
2. Again... if you know how to code to add/remove views in certain sections the code for the views is here and you need also to modify the appropriate section file like ViewsVideos.xml, ViewsMusic.xml, ViewsPictures.xml & ViewsAddons.xml.
Cheers
Nessus
