2022-05-26, 10:15
Dear All,
I'm in need for some help with local info, movie sets and poster images. I searched through the forum, and googled my as off, but can't find a thing related to my problem.
Currently I'm using kodie 19.1.0 Matrix, Aeon Nox Silvo 8.01, local NFO files, Movie Sets, Movie Set Information Folder, and single poster/fanart images in movie folders.
I'm using the MSIF folder for the genre category selection, and as soon as in the genre selection I use the moviename-fanart/poster naming for the individual movies in the set. These category selections are then added to the favorites option to easily accees their content.
Category genres are created using the local NFO files, and used are documentaries/documentaries entertainment/movies/movies animation/series/series animation.
My problem is with poster images. I'm sure that I read somewhere in the past year I've been using Kodi, that you could use unlimited posters in the MSIF folder.
The intention was that e.g. in the movies category, I currently have 158 movies, to add all the images for the covers to the MSIF folder as posters, so 158 poster covers. As soon as you would scroll over the movie category using the remote, the choosen background image for that category would show, and the available movies in the set would be scrolled through by their poster images. When entering it, each movie in the set would have it's own background/poster named in the folder where it resides using moviename-fanart/poster naming.
I tested this using a few movies, which worked really well for me. Then though I discovered that there's a limit of 21 posters, meaning poster.jpg and then poster1-20.jpg, which completely destroys my intended way of working.
Now I've found mentioning of "Poster Sets", but for the life of me am not able to figure it out. It states there can be serveral sets per movie, which would possibly solve my dillema. Some info suggest the naming/numbering I already use, so poster1-x. Some info suggests using poster-01-01, where the 1st 01 is the setnumber, and the 2nd the number in the set. Similar is information found to use poster-1-1 naming.
-Does anyone have any idea, or can kick me in the right direction?
-Can this be solved using the naming I already use, being poster1-x, or is there another way?
Any and all hints/tips are greatly appreciated.
Thanks in advance for any help.
