Full Version: dolby vision green
I use the Kodi-HDR-Edition and the tv is sony x95j
I have a mp4 video like this:
Quote:Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : hev1
Codec ID/Info : High Efficiency Video Coding
Duration : 2 h 28 min
Bit rate : 13.8 Mb/s
Width : 3 840 pixels
Height : 1 640 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.091
Stream size : 14.3 GiB (98%)
Color range : Full
Codec configuration box : hvcC+dvcC
This video can play normally on tv buit-in player and infuse on ipad, but on kodi, the video looks "green"
But if I package it to mkv, the video can play normally on kodi:
Quote:Video
Format : HEVC
Codec ID : V_MPEGH/ISO/HEVC
Color space : YUV
Bit depth : 10 bits
Default : Yes
Forced : No
Color range : Full
After I tried some other videos, I find that if the Codec ID is hev1, the video can not play normally on Kodi.
When I use dolby official mp4muxer, if I set --dv-profile to 4 or 7, the Codec ID will be hev1 but if I set it to 5, the Codec ID is dvhe.
So here is my question:
1.Why profile 4 7 use hev1 and profile 5 uses dvhe, what is the difference?
2.In the line of HDR format, there is "dvhe.05.06"(in my first videro info), but Codec ID is hev1, what is the difference of these strings?
3.Why kodi can not play Codec ID hev1 video but other players can?
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
