Full Version: BTplay - Bluetooth audio switcher for Linux
BTplay
Bluetooth audio output switching for Kodi 18 on Linux: switches audio output between current device and Bluealsa.
PREREQUISITES
1. Bluealsa up and running
2. Bluetooth device connected to system (obviously, it has to be trusted to connect automatically)
3. "Allow remote control via HTTP" in Kodi settings turned on
It stores current audio device before switch to Bluealsa and restores it after Bluealsa switch off.
USING
Input Your port number and credencials from Kodi "Web server" settings page (Settings -> Control -> Web server)
If port number isn't inputted, addon falls back to standard HTTP port 80 which is probably not what You want
If username or password isn't inputted, addon omits authorization, so minimalistic setting is port number only; one should use username/password fields only if it used in Kodi itself.
If You select Bluetooth play multiple times by mistake, it doesn't lead to errors - right non-BT device will be restored anyway
Download addon
P.S. I can't remember where I found icon for that addon, so my apologies to that person in copyright meaning.
Does anybody know if this works with v19 Matrix and above?
Seems to me that this should be basic functionality in this day and age...
