Hi world,
I'm a kodi user since sooo long (a XBMC user on xbox1 to be precise !) ... and I'ml sooo grateful for the result now in 2022.
Since some years, I have more and more movies not found by scrapper, even when I copy-paste the exact title from TMDB ... annoying ...
So here is the idea : the scrapper could take the TMDB #id directly from filename when detected ... ie : "LotR - Two Towers (2002)(tmdb#122).mkv"
Something like that already exist during movie searching but it's not really easy to use imo.
Thanks for reading
Z3b
The funy part is that looks already here ...
from
https://github.com/xbmc/metadata.themovi...er/tmdb.py
Quote:def _parse_media_id(title):
if title.startswith('tt') and title[2:].isdigit():
return {'type': 'imdb', 'id':title} # IMDB ID works alone because it is clear
title = title.lower()
if title.startswith('tmdb/') and title[5:].isdigit(): # TMDB ID
return {'type': 'tmdb', 'id':title[5:]}
elif title.startswith('imdb/tt') and title[7:].isdigit(): # IMDB ID with prefix to match
return {'type': 'imdb', 'id':title[5:]}
return None
and if i rename my file "tt4574334.mkv" ... magic ... thie file is now a well known TV show ...
...work in progress ...
I'm not a dev python, but I think something like that could work :
python:
elif title.find("(tmdb#")!=-1 and title[title.find("(tmdb#")+6:-1].isdigit():
return {'type': 'tmdb', 'id':title[title.find("(tmdb#")+6:-1]}
return None
Z3b2G
Someone has asked about this also a few days ago. See the reply by @
rmrector ...
https://forum.kodi.tv/showthread.php?tid...pid3098741
And code proposal a few posts further down.
If you make the change to the code in your local files, you could test and if it works submit a pull request. rmrector is pretty busy these days, so I am sure he will appreciate the help.
as i post 2 posts below, i hope my code works with imdb number (with the restrictition of the date position)
if you want the tmbd number working the same way
try to add in addons\metadata.themoviedb.org.python\python\lib\tmdbscraper\tmdb.py
python:
m=re.search(r"(tt\d+)",title)
if m: return {'type': 'imdb', 'id':m.group()}
m=re.search(r"tmdb[\/#](\d+)",title) #work with tmdb/number and tmdb#number
if m: return {'type': tmdb', 'id':m.group()}
368312 (thread)
this works (i hope) with tmdb python scraper and this code will be erase when this scaper will be update by kodi updater addon
soooo great ... I will test that asap.
if this works as I think it will, I will finally have THE ultimate solution for movie scrapping ! ... perfect, ty for the help.
Thanks to everyone
Z3b
python:
if m: return {'type': 'tmdb', 'id':m.group()[5:]}
return None
fix : with tmdb, 'id' should only contain the id ...
( am I wrong ? )
have you try ?
with m=re.search(r"tmdb[\/#](\d+)",title) m.group() return the numbers only.
(2022-05-30, 11:59)michelb2 Wrote: [ -> ]have you try ?
I have just test it in python online sandbox and it return the whole pattern ... but you are right : it should not ...
https://pythonsandbox.com/code/pythonsan...jRUM_v0.py
Dixit python doc :
.group()
returns the part of the string where there was a match
So ...
(Yes, i'm pure newbie to python ... 😁)
(2022-05-30, 14:03)Z3b2G Wrote: [ -> ](Yes, i'm pure newbie to python ... 😁)
I'm no developer either, but make sure you are using Python-3 compatible syntax. Python-2 is EOL.
ok i try inside kodi200 , i agree with you
if m: return {'type': 'tmdb', 'id':m.group()[5:]} is the good syntax
if m: return {'type': 'tmdb', 'id':m.group(1)} is a good synax also
(by i am not a python developper either)
m.group() return the whole match
m.group(1) return the first group match inside ()
Quote:Match.group([group1, ...])
Returns one or more subgroups of the match. If there is a single argument, the result is a single string; if there are multiple arguments, the result is a tuple with one item per argument. Without arguments, group1 defaults to zero (the whole match is returned). If a groupN argument is zero, the corresponding return value is the entire matching string; if it is in the inclusive range [1..99], it is the string matching the corresponding parenthesized group. If a group number is negative or larger than the number of groups defined in the pattern, an IndexError exception is raised. If a group is contained in a part of the pattern that did not match, the corresponding result is None. If a group is contained in a part of the pattern that matched multiple times, the last match is returned.
ok, so we are noobs ... but we done it !
python:
is far better imo.
I will test that soon, you already test ?
bye.
