2022-06-06, 23:02
2022-06-06, 23:34
(2022-06-06, 23:02)Afonzo Wrote: [ -> ]Is there a setting that might slow down Amber? If yes, what setting could that be?
You really believe there would a skin setting for "Okay, let's slow things down for now"..? I think not.
Provide a debug log (wiki), I'm thinking it's some add-on / background process that is taking up cpu cycles.
2022-06-07, 00:07
Quote:You really believe there would a skin setting for "Okay, let's slow things down for now"..?No, I don't. But I would wonder what that setting might be good for. Maybe for people who find Kodi running too fast.
Quote: Provide a debug log (wiki), I'm thinking it's some add-on / background process that is taking up cpu cycles.OK, thank you for the link, I will do it.
2022-06-18, 22:47
@Afonzo , are you running Matrix or Nexus? What OS are you using? What type for machine? Amber has a lot of features, some which require more processing power than others. If you provide me info on your environment, I could recommend what to enable/disable so that you get better performance with Amber. Thanks.
Regards,
Bart
Regards,
Bart
2022-06-19, 20:51
