Full Version: Kodi scraper fail to fetch movie detail from TMDB
Hi, I'm using Kodi to stream movies from my local network, most of the movies are listed in this format.
BabyDriver.2017.BRRip.Dual.mkv
BeautyAndTheBeast.2009.BRRip.Dual.mp4
Where the capital case is being used instead of space or dash as separator and unfortunately these movies' details are failed and not fetch by tmdb via kodi scrapper, is there some settings we can do to make to make these capital case as space separator?
Thanks for any help
(2022-06-10, 22:00)mzubair Wrote: [ -> ]is there some settings we can do to make to make these capital case as space separator?
No.
The only thing that springs to mind is Clean Strings, but I don't think it will do what you need... https://kodi.wiki/view/Advancedsettings....eanstrings
Other ways are...
You can use a Parsing NFO file... https://kodi.wiki/view/NFO_files/Parsing
or
Use the Scraper Search... https://kodi.wiki/view/Add-on:The_Movie_...hon#Search
or
Use movie folders. Leave your filename as is but name the folder Baby Driver (2017) and set the Source to use Movie Folders so the search name is made from the folder name.
Thread moved to movie scraper support
