2022-06-17, 00:08
Greetings fellow Linux users!
I recently inherited a GT1030 (an Asus GT1030-2G-CSM to be exact) and I have a question about this card outputting 4k at 60Hz.
Sometimes Fox Sports (I was using @matthuisman 's excellent Fox Sports add-on) will show games in 4k 60fps, like last Sunday for the USFL game. I found it odd that the card was playing the content but it was being output at 1080p60. It seems like 59.94Hz is what this card can output max at 4k. I am using nvidia-driver-510.
xrandr output:
Hooking up an NVidia Shield to this TV shows that 4k60 is possible on the TV, as that allows me to switch to a 4k60 resolution and allows me to whitelist a 4k60 resolution.
Can any other GT1030 owners confirm that they can or cannot use 4k60 on Linux?
Thank you!
xrandr output:
code:Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
DVI-D-0 disconnected primary (normal left inverted right x axis y axis)
HDMI-0 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
3840x2160 30.00*+ 59.94 50.00 29.97 25.00 23.98
4096x2160 59.94 50.00 29.97 25.00 24.00 23.98
1920x1080 60.00 59.94 50.00 29.97 25.00 23.98 60.00 50.04
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1366x768 59.79
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
Thank you!
