2022-06-17, 15:33
Hello,
I've just receveid a Mi Box S and I've installed Kodi (19.3) to turn the box as a media center. I've plug a external HDD to the box.
So far, I've two issues.
1. Add the HDD as a media source :
I can see the HDD in the file browser of Kodi and I can navigate through directories but I can't add it as a media source. If I go to "Add video source" and then "Browse" I can select the HDD and if I select "External storage" I've the drive of the Mi Box. "Root filsystem" does nothing.
If I go in the file info menu and storage I can see an "storage/emulated/0" which is the drive of the box and a "storage/longcode" which size is the size of the HDD.
Question : how can I add my HDD as a source ?
2. Passthrough :
My box is connected via an optical cable to a surround system and I want that the media with DTS go to this system. The problem here is that I can select the passthrough option which is disabled.
Question : how can I activate the passthrough option ?
All works fine with this setup on a RPI3.
2. Passthrough :
