I recently added some more movies to my Kodi library. Some of the movies already existed in the library, but these I have edited by supplieing subtitles etc. Kodi finds the correct posters for all movies, but the newly added or edited movies have no information. All of the old movies show information. I use the latest version of Kodi in Windows 11, 64 bit. All add-ons are updated etc.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I have tried to upload the logfile both manually and by using the Kodi Log Uploader with no success. Nothing seems to happen.
fltk
Yep, that is correct. Unfortunately there is nothing in the log of any help. You specifically state movies, but all I see are TV Shows.
But, you are using a dead scraper for tv shows.
metadata.tvdb.com is a broken scraper and no longer in the repository. If you want to continue using TVDB, then change to the new
TVDB v4 scraper.
https://forum.kodi.tv/showthread.php?tid=368272
No 4 in this image...
https://forum.kodi.tv/showthread.php?tid=363391
(2022-06-21, 11:25)fltk Wrote: [ -> ]Kodi finds the correct posters for all movies, but the newly added or edited movies have no information.
I need to see this in the log. So try adding a new movie and capture it in the
Debug Log.
I think you are using Universal Movie Scraper, and there is a problem with the Plot...
https://forum.kodi.tv/showthread.php?tid...pid3101096
Probably best to switch to
The Movie Database Python scraper which is movie scraper no 7 in the above link.
