Full Version: Win10 PVR buffer problem
hello,
i saw somewhere that pvr buffer is about 8 seconds and it will fill to 20% when some channel is tuned.
i use two dvb-s2 tuners, one connected via usb (dvbsky) and second one connected via network (vu+) and dvbviewer as a backend. no issue with dvbsky which is connected via usb.
but whenever i tune any channel from vu+ which is connected via network i can see that it's buffered to 10-15% and this leads to sound shuttering and i can hear as the sound goes slower (while buffering) and then faster (to normal speed) and again and again as it's still underbuffered.
when i simply pause that channel for let's say 2-3 seconds so the buffer jump to ~40% then all these problems disappears.
so please would be possible to implement an option to extend buffer to say 50%? because it annoying to pause channel for few second whenever is tuned.
there is no issue when i try to tune any channel in dvbviewer itself.
https://paste.kodi.tv/jiyunagabi.kodi
thanks
Since backends implement this differently there is no generic solution so you would need this addressed by your client/backend combo.
Martin
okay, i posted this into parent PVR forum (https://forum.kodi.tv/showthread.php?tid=368686) and i was forwarded here as i use DMS as a backend, so it's simple copy/paste:
but whenever i tune any channel from vu+ which is connected via network i can see that the buffer says 10-15% and this leads to sound shuttering and i can hear as the sound goes slower (while buffering) and then faster (to normal speed) and again and again as it's still underbuffered.
when i simply pause that channel for let's say 2-3 seconds so the buffer jumps to ~40% then all these problems disappears.
The PVR does not implement any buffering apart from optional timeshifting. Video buffering is handled by Kodi. You can try enabling timeshifting or try these settings: https://kodi.wiki/view/HOW-TO:Modify_the_video_cache
so WHAT implements PVR buffering? i was send here from parent pvr forum ...
and yes i have timeshift in place and as i said when i pause it for 2-3 seconds to buffer to at least 40% the issue is gone ...
so noone manages pvr buffer?
