I see AudioTrack (RAW) Android IEC packer (greyed out) when connecting my USB DAC to Kodi Android (downloaded from Play store).
Should I be seeing my DAC's name or is the above fine? I tried two different USB DAC's connected to a Pixel 6.
Kodi only sees what Android sees, which is: "Audiotrack" and nothing else ... unlike in Linux where we can enumerate devices explicitely on Android everything goes via the Audiotrack API. If it's not exposed, we don't see it.
this went so over my head
so the USB DAC is being used or not used?
I think you're saying it can't see the usb dac?
Kodi has no idea what you have attached to the android box. It only asks Android itself: Give me your output device please. Then it uses what Android gives it.
OK, TY. My eyes are rolling around so I'm having some issues thinking straight.
