2022-06-25, 07:02
Hi
I am fairly new to this forum and I hope I can find an answer to what I try to achieve. I use a rasberry pi, libreelec kodi 9.28 madnox skin and the addon iptv simple client. I am trying to create a shortcut to the window to the channel groups. I'm trying to add a "Change action" in the sub menu through a "ActivateWindow(....). I found that it is possible to open the "pvrgroupmanager", but I just wat to open the groups to select from. I checked the window ID's but not find this in the list. I hope that this is the correct description of what I want to achieve.
Is it possible to create that short cut and what would be the windows ID?
