2022-07-10, 01:21
When attempting to install kodi on my raspberry pi 4, I see the following errors
I was having this issue while on Buster version of Raspbian. I tried updating to Bullseye to no avail. Any advice would be appreciated
text:
pi4 ~ ▸ sudo apt-get install kodi
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
kodi : Depends: kodi-bin (>= 2:18.7-1~buster) but it is not going to be installed
Depends: kodi-bin (< 2:18.7-1~buster.1~) but it is not going to be installed
Depends: python-bluez but it is not installable or
python-lightblue but it is not installable
Depends: python-imaging but it is not installable or
python-pil but it is not installable
Depends: python-simplejson but it is not installable
Depends: libnfs12 but it is not installable or
libnfs8 but it is not installable or
libnfs4 but it is not installable or
libnfs1 but it is not installable
Recommends: libva-intel-vaapi-driver but it is not installable
Recommends: libva1 but it is not installable
E: Unable to correct problems, you have held broken packages.
