Full Version: Movie doesn't show 4K icon while browsing
IT shows '4k' when playing the movie.
How is this info determined? By resolution?
Another file for the same movie with same resolution shows '4k' while browsing the movie. The only difference I can see is that the problematic movie is x264 (the others are x265). Is this a bug?
Which skin? And does it show 4K after you've played the video?
Confluence.
No, I didn't play the video. I tried to remove the item from library and scan it again.
