Never happens when watching, but happens regularly when nobody is looking...so I obviously have no idea what's going on. I've got log, old log, crash log, stacktrace.... must figure out where to post those, suggestions? kodi.old.log posted to paste.kodi.tv... no idea how this works....
Win 10x64 fresh install, patched to date
Kodi 19.4.0
(2022-07-20, 19:37)bikesquid Wrote: [ -> ]kodi.old.log posted to paste.kodi.tv... no idea how this works....
You paste the log into paste.kodi.tv, press the floppy icon (or CTRL-S) and you get a new URL in your web browser. Copy/paste that url here into the forum. If there is a message that the log is too large, try
https://paste.ubuntu.com .
INFO <general>: Disabled debug logging due to GUI setting. Level 0.
Let's start first by enabling debugging in Kodi, and re-reproduce the error(s) in a new Kodi log file.
Well, since timing is random, I'm not really able to convince the peanut gallery to watch all the diag info on the screen when trying to watch TV. Any way of turning that off?
(2022-07-20, 19:37)bikesquid Wrote: [ -> ]Never happens when watching, but happens regularly when nobody is looking..
Sounds a bit like quantum entanglement ?
I find that some users issues can be solved in the properties of the shortcut (or launch icon) setting the o/s compatibility mode, worth a shot. I should note that once you've had a crash, there is no effective limits on the code splatter, the base underlying code has undoubtedly compromised (without a reboot of the o/s) subsequent launches will could run into the same issue. Kodi is a venue for junior coders to try their skills, as such there is a mirad amount of very attractive add-ons; which support is relegated to one o/s or one iteration of Kodi and crashes abound (stick to supported extras with forums to engage the developers).
(2022-07-29, 03:03)blakblu Wrote: [ -> ]people in the forums are not able to help, the log files are completely useless!
Smack! venting - no point in posting then? If debug is not turned on, the log file doesn't impart as much information as it could. From what you've posted it looks like you haven't kept your hardware current and enjoy depreciated plugins/add-ons and skins. It's a shame users don't want to admit they're cheap and don't want to keep their limited hardware current. I don't blame them though, as a lot of cheap stuff can't be upgraded. As 'Klojum' pointed out your record it's apparent that you don't frequent the forums on a regular basis, hence most of the issues you have had in the past have been dealt with notations and solves. (e.g. 4K 10+bit, atmos, dolby etc have been a challenge with old hardware when users think it should 'just work'.)
(2022-07-29, 03:15)Karellen Wrote: [ -> ]I really find it difficult to believe that you have the same problem across 10 devices and multiple operating systems.
I'll agree with this statement 100% and with millions of users, suggest you check voltages and inconsistency with power-line current (brown outs etc).
Well, since turning on debug logging level, it has been stable...🙄
Stable for longer than is typical these days. So, I'll be back if the problem comes back!✌
(2022-07-30, 02:34)bikesquid Wrote: [ -> ]I'll be back
Very Schwarzenegger; hopefully with a full debug log posted to a public paste-bin and that URL linked to the post.
OK, "Success!!"... 🙄 ... it crashed!! Two days in a row....
Here's the last bit of the mucho grande log. Hope it helps isolate the crashing.
The associated stacktrace says:
Thread 2976 (process 7804)
# 0
ivazagokef.kodi (paste)
The log is huge, tried to paste it all and the paste bin spasms, chokes, and spits... got what i could get it to take.... normally I just zip and pm such things.... 🤷♂️.
Have done the two suggestions. We'll see. Cheers.
(2022-08-10, 04:08)bikesquid Wrote: [ -> ]Have done the two suggestions. We'll see. Cheers.
Let us know if that helps in anyway.
If not, zip your log up, post it somewhere and we'll download the zip
(2022-08-10, 03:54)bikesquid Wrote: [ -> ]The log is huge,
You can also cut the log into smaller pieces and upload them separately.
