Full Version: Custom season name not appearing in episodes
Hello, if I edit a season title (for example the season 1 title of a tv show), in the episodes view it won't show the custom season title in the top left corner but "Season 1" how can I fix that by editing xml files ?
Seems like a bug to me. At least I can confirm this issue. Not sure how to fix that by editing skin files. I've checked the database and I see the edited title is also mentioned at the db as well.
@Hitcher Do you have an idea?
Same thing happens with Estuary and they both display Container.FolderName which doesn't seem to return the renamed season folder in this case.
Oh okay thanks, if it’s a bug I think I should wait for it to be fixed
You'll need to report it on GitHub for it to be known about.
