2022-08-05, 20:41
2022-08-05, 20:44
(2022-08-05, 20:41)Skotland Wrote: [ -> ]using VPNNot our problem as per our VPN policy (wiki). Kodi itself works fine without a VPN.
(2022-08-05, 20:41)Skotland Wrote: [ -> ]Everything worked fine till yesterday.today errors. Can you assist please?We'd like your full debug log (wiki) please.
2022-08-05, 20:46
Ok please tell me how to get that
2022-08-05, 21:38
(2022-08-05, 20:46)Skotland Wrote: [ -> ]Ok please tell me how to get that
You copy the contents of the logfile into the paste.kodi.tv web page. THEN you click on the diskette icon (or press CTRL-S on your keyboard), and the log file will be stored AND a new URL will appear. Copy/paste that new URL here into the forum.
2022-08-05, 21:54
We have Kodi on Google TV and I am trying to give you the log from my phone but I shall try again thanks for your patience
2022-08-05, 22:05
"hastebin" https://paste.kodi.tv. Let me know if this is of help. Thanks
2022-08-06, 06:50
https://paste.kodi.tv/ is the starting page, it does not contain a log file.
This is a URL with contents: https://paste.kodi.tv/iwupamizif
Kodi also has a Kodi Log Uploader add-on, https://kodi.wiki/view/Add-on:Kodi_Logfile_Uploader . Try installing that.
2022-08-06, 07:21
If your using a VPN, don't bother with the log.
DStv most likely now blocking your vpn.
You can confirm that by trying their website.
There are no other reports of issues (https://mybroadband.co.za/forum/threads/...on.977513/) so it'll be something your end and nothing we can do to fix sorry
2022-08-10, 17:14
Hi everyone, I’m also having the same issue. DSTV now works on my phone and on the website but doesn’t work via the Kodi Add-on. Here’s a log file replicating the issue. Would appreciate any response
https://paste.kodi.tv/uqesocogam
Thank you 🙏
Thank you 🙏
2022-08-29, 22:18
I need assistance with showmax as it's throwing up a unexpected error after putting in the in details please help
2022-09-02, 09:41
(2022-08-29, 22:18)Collindeo Wrote: [ -> ]I need assistance with showmax as it's throwing up a unexpected error after putting in the in details please helpfixed in version 0.27.4 just released
2022-10-28, 20:58
Hi I need assistance my dstv isn't working and I've downloaded the new version on kodi but it won't let me play dstv it takes long and it throws up a Grey fuzz could.you please assist
2022-12-02, 15:05
Getting a playback error in DSTV, below is the error, it mentions inputstream adaptive, but this seems to be working with majority other Slyguy add ons.....
2022-12-02 13:01:37.422 T:11176 INFO <general>: Creating InputStream
2022-12-02 13:01:37.424 T:11176 INFO <general>: AddOnLog: inputstream.adaptive: SetVideoResolution (1920 x 2081)
2022-12-02 13:01:37.425 T:11176 ERROR <general>: XFILE::CDirectory::GetDirectory - Error getting C:\Program Files\Kodi\addons\inputstream.adaptive\
2022-12-02 13:01:40.221 T:6052 ERROR <general>: script.module.slyguy - mismatched tag: line 4, column 2
File "C:\Users\mcunn\AppData\Roaming\Kodi\addons\script.module.slyguy\resources\lib\proxy.py", line 236, in do_GET
self._parse_dash(response)
File "C:\Users\mcunn\AppData\Roaming\Kodi\addons\script.module.slyguy\resources\lib\proxy.py", line 400, in _parse_dash
root = parseString(data.encode('utf8'))
File "C:\Program Files\Kodi\system\python\Lib\xml\dom\minidom.py", line 1969, in parseString
return expatbuilder.parseString(string)
File "C:\Program Files\Kodi\system\python\Lib\xml\dom\expatbuilder.py", line 925, in parseString
return builder.parseString(string)
File "C:\Program Files\Kodi\system\python\Lib\xml\dom\expatbuilder.py", line 223, in parseString
parser.Parse(string, True)
xml.parsers.expat.ExpatError: mismatched tag: line 4, column 2
2022-12-02 13:01:40.221 T:11176 INFO <general>: AddOnLog: inputstream.adaptive: Successfully parsed manifest file. #Periods: 1, #Streams in first period: 1, Type: VOD, Download speed: 0.0000 Bytes/s
2022-12-02 13:01:40.222 T:11176 INFO <general>: Creating Demuxer
2022-12-02 13:01:40.222 T:11176 INFO <general>: Opening stream: 1001 source: 256
2022-12-02 13:01:40.733 T:11176 ERROR <general>: AddOnLog: inputstream.adaptive: No MOOV in stream!
2022-12-02 13:01:40.733 T:11176 WARNING <general>: CVideoPlayer::OpenStream - Unsupported stream 1001. Stream disabled.
2022-12-02 13:01:40.733 T:11176 INFO <general>: CVideoPlayer:rocess - eof reading from demuxer
2022-12-02 13:01:40.733 T:11176 INFO <general>: CVideoPlayer::OnExit()
2022-12-02 13:01:40.733 T:11176 INFO <general>: VideoPlayer: eof, waiting for queues to empty
2022-12-02 13:01:40.734 T:11176 INFO <general>: ADDON: Dll Destroyed - InputStream Adaptive
