2022-08-21, 08:01
2022-08-22, 19:56
(2022-08-21, 08:01)Hagar1 Wrote: [ -> ]Kodi plays audio fine but says the audio is undetermined and ghosted.Think you'll have to be more articulate, as in a video settings, playing audio from what source? Perhaps the scraper hasn't pulled in the data, or the file is not in the library? A debug log might give us a clue to what is, but personally if everything works, why rock the boat.
2022-08-23, 03:26
Your right, I because I knew and well...
I took some screenshots and lo and behold, I think its a "ACC" thing. Most other formats don't seem to show "undetermined". And yet I'm getting 5 to 1 sound from even ACC
So I may not have an issue after all, but here are some pics.
https://drive.google.com/file/d/1EsZJbJY...sp=sharing
https://drive.google.com/file/d/1X7n-Ep1...sp=sharing
https://drive.google.com/file/d/1aq9kPiJ...sp=sharing
https://drive.google.com/file/d/15eEX4HN...sp=sharing
and
https://drive.google.com/file/d/1UPWFHWf...sp=sharing
Dave
and
Dave
2022-08-23, 11:38
You have not provided user access to the screenshots that you have posted links for. Anyway a full Debug Log would be a much better way of figuring out what is going on as opposed to a few pictures.
Also you have not provided any of the information PatK has asked for to provide you with some assistance.
2022-08-24, 01:43
Arggg, Hopefully I fixed the restricted thing and hoping those screen shots show the issue I might be having. As I said, I believe this is a "ACC" audio format issue.
Thanks,
Dave
And the red warning states: Do Not post Logs in the forum. Use kodi.tv instead.
So when and or if I need to post a log and I'm not sure how yet. Guess I'll do it there.
Thanks,
Dave
2022-08-24, 02:46
(2022-08-23, 03:26)Hagar1 Wrote: [ -> ]So I may not have an issue after all, but here are some pics.Yes, I don't think there is an issue here; Appears to be a label missing in the encode, I've seen plenty and doesn't effect the audio. BTW your images do show now.
(2022-08-24, 01:43)Hagar1 Wrote: [ -> ]if I need to post a log and I'm not sure how yet.Cut the kodi.log Cntl+C ; Go to the public paste-bin, and Cntl+V will paste the log contents into the big black space, 'create new paste', copy the URL line.. at the top of the page and add this link to your post in the forum (be sure to turn on logging in settings).
2022-08-24, 19:39
(2022-08-24, 01:43)Hagar1 Wrote: [ -> ]And the red warning states: Do Not post Logs in the forum. Use kodi.tv instead.
The link I provided will assist you to provide a link to your log but like Pat says it just seems the audio is just not correctly labelled (hence "undetermined"), not an issue unless you have multiple audio tracks and need to know which is which. If you want to see if anyone can delve a little deeper with it then yes, the Debug Log is the way to go.
