Full Version: Enabling audio passthrough
Hello,
I am running Dolby atmos fine on Netflix and local.
But in Kodi I do not have TrueHD and other extensions for audio passthrough.
Could you help me enable all options so I can play the format?
The output device is HDMI to the Samsung soundbar system.
Here is the debug: https://paste.kodi.tv/jofoziwaxo.kodi
Setting output to WASAPI default fixed it.
Now all options are visible and I see Dolby atmos.
(2022-08-21, 14:21)geimara Wrote: [ -> ]Setting output to WASAPI default fixed it.
A lot of these settings are hardware dependent, if the soundbar doesn't have this capability and you're using pass-through, it could be an issue. In any case 'll mark this thread solved.
Thread marked solved.
