2022-08-26, 07:39
2022-08-26, 07:39
2022-09-01, 21:26
I need to Ember log file.
2022-09-02, 03:47
(2022-09-01, 21:26)DanCooper Wrote: [ -> ]I need to Ember log file.
what is the recommended way to show a big log (1.37 MB)?
I can't paste on pastebin since it is too big
pastebin error
"You have exceeded the maximum size of 512 kilobytes per Paste."
Anyway try this one from kodi paste
https://paste.kodi.tv/gayofanopo.kodi
2022-09-07, 22:22
Looks like there is a problem to load an actor image (mayby a 0 kb / empty image). If that error happens on each start it should be the image of the first / top actor in the movie that is in the first position. The log dosn't tell me the image path is, only that it happens on "lstActors_SelectedValueChanged => LoadFromFile => Bitmap".
2022-09-08, 11:26
(2022-09-07, 22:22)DanCooper Wrote: [ -> ]Looks like there is a problem to load an actor image (mayby a 0 kb / empty image). If that error happens on each start it should be the image of the first / top actor in the movie that is in the first position. The log dosn't tell me the image path is, only that it happens on "lstActors_SelectedValueChanged => LoadFromFile => Bitmap".
Do you need for more info ie image path or will that log be sufficient to fix the bug?
What software do you use to view the log, excel or some other software?
