2022-09-16, 10:45
Is kodi on shield pro able to play 3d mkv files?(i did the pull the 3d file then merge them bit to play on my oppo 203).
I just got around to assembling my new system however the return date is days away and just remembered i forgot to check if there was a problem with 3d with this setup. Its going to take me a bit to set up nas and feeling the crunch. I was surprised how little info i found on it except shield wont support it…however that doesn't mean it wont work if the file is done correctly.
When i get to test it will i be happy or frustrated. Id prefer to leave the box uNopened if getting 3d to work will be fatalist endeavor.
Anyone already tried or doing this?
