Full Version: FireTV-Stick - Issue with "MediaPortal PVR Client" version 20.2.0
As PVR-Backend I am using MeiaPortal TV-Server, Version 1.30.000.0.
The IP-Address is 192.168.3.62:9596
Within the "MediaPortal PVR Client" version 20.2.0 of Kodi Version 20.0-ALPHA3 I setup the IP-Address is 192.168.3.62:9596.
THE PVR Client is conntecting to MediaPortal and I can see within the TV menue the channels, the programm overview and the recordings. But when I start live TV, after round about 2 minutes, I receive in german language the error "Ein allgemeiner Fehler ist aufgetreten" = an common error occured.
From the log file I can see that the PVR client is connecting to the correct IP Address, but get afterwards a responce from an IP-Address which is different = 192.168.3.64; instead of 192.168.3.62.
Error message: SMBFile->Open: Unable to open file: 'smb://192.168.3.64/timeshiftbuffer/.....unix_err:'71' error: 'No route to host'
The same issue I had in the past already with the Kodi version 19.4 on Android FireTV-Stick. But with Kodi version 18.9 everything was workinng fine.
